Installed the inspection plates on the aft fuselage. The plates should be just aft of center because the forward edge on the plate will hit the rivet line and the forward screw will hit the vertical member. The screw interference might be avoided by mounting the holes at a 45 degree angle (X) instead of the way it is shown in the plans (+).
Prepared the canopy hinges D02-11 and -12. These attach to the right upper forward longeron. Holes in the aft part of the longeron needed adjustment per ONX- F11 rev B to fit the -12 hinge.
Also need to adjust holes on the mid section of the longeron per Rev B.
Added the AN3 fuel tank strap holes on both upper longerons using dimensions on F04-01. I transferred these to the glareshield and enlarged the holes in the glareshield to 7/16" for AN3 bolt head clearance. This will allow removing/installing the glareshield without disturbing the tank installation.
